AEG OKO LAVAMAT 72600 Update
Home Forums Public Support Forums Help And Support Washing Machine Help Forum AEG OKO LAVAMAT 72600 Update
  • #30759
    b11tch
    Hi all,
    I’m hoping that someone can help me out, I have a problem with the above machine. Originally I had the water distributor problem with the clicking coming from behind the detergent drawer. so I replaced this without any problems. Now the washer will start washing but then stop with 38mins remaining, the mainwash light is still on and the drum still agitating. it’s possible to complete a wash only when set to “cold” wash. If I set quick wash it stops at 27mins.
    The heater element checks out okay.
    I would appreciate any guidance offered.
    Thanks.
    #228305
    helo_75
    if the heater does indeed check out ok, maybe its a thermistor/pcb problem, possibly a pressure switch fault
    call someone proffesional in, and theyll get into the diagnostics, and it will tell you itself whats wrong
    aint an easy one, that im afraid
