aeg oko-lavamat 86720 update C9 error
Home Forums Public Support Forums Help And Support Washing Machine Help Forum aeg oko-lavamat 86720 update C9 error
  • #57905
    slyp98
    hi guys , i have this m/c and it has a C9 error , goes through the cycle fine , but drum not turning i removed the motor and the brushes were worn to nothing on one side , replaced both and cleaned the comutator , installed the motor but i’m still getting C9 drum still not turning anyone know the reset for this m/c thanks
    #332626
    Re: aeg oko-lavamat 86720 update C9 error
    No reset needed.
    If one of the brushes was worn right down but the other was much longer that is usually a sign of a faulty armature within the motor.
    Have you tested the motor with a multimeter or meggar?
    #332627
    slyp98
    no didnt test , do you know any values for the resistance tests cheers
    #332628
    Sorry, I don’t have the specific resistance figures. I would be checking for continuity first though if you get no sign of life at all from the motor.
    #332629
    slyp98
    will do that and get back
