AEG OKO Lavamat 88730 Fault C1
Home Forums Public Support Forums Help And Support Washing Machine Help Forum AEG OKO Lavamat 88730 Fault C1
Viewing 1 post (of 1 total)
  • #82882
    leeg123
    I have a code 1 fault which appears to be due to a filling problem.
    The water supply pressure is fine, the hose and filter are clear. The machine fills slowly on “rinse” mode, but not prewash or main wash.
    The 3 way valve I removed appears un-blocked externally, and there is continuity on all 3 solenoids. A buzzing sound at the start of the cycles suggests the valves are trying to open.
    Can anyone please advise what I should do, does this sound like I need a new 3 way valve, don`t want to pay £50 if this is not problem.
    Thanking you in anticipation
    Lee.
