However, check the pump filter, your pump is not working with a code C2 showing most probably 😉 .
Do please read your Instruction Booklet for further tips. Beyond that and for further advice , please do give us the MODEL number andPNC No of your machine 😀
Re: AEG OKO-LAVAMAT Model number 74620 fault code C2
Thanks Martin. 😆
Just for information for anyone else looking for info on the same problem, I spoke direct with AEG and they informed me that the C2 code can point to four problems.
1. The outlet hose is too high
2. The outlet hose is twisted or blocked
3. The drain pump is blocked
4. The drain pump is broken
