Re: AEG OKO Lavamat Turbo 16800 – Noisy
Gets louder on spin? Almost certainly drum bearings. Open the door, put hand up at 12 o’clock and try to lift. If there is any movement of the lip of the drum in relation to the inner edge of the door seal, the bearings are on their way out. Often, if you turn the drum by hand, you can feel a slight roughness.
If the above is true, this is at least an hour and a half’s work for a professional as it involves (quite literally!) the demolition of the machine to its component parts.
I would seriously consider professional help……. Click the link below to see if there is a UKW engineer in your area.
Power off if you are going to investigate further.
