AEG oko-lavamaty 88730 washing machine error codes
Home Forums Public Support Forums Help And Support Washing Machine Help Forum AEG oko-lavamaty 88730 washing machine error codes
  • #7090
    My machine has just stopped in mid cycle with a high pitched whistle and the error code C3. I had to open the door manually; the washing had not got to the rinse stage. Any ideas?
    #121332
    Re: AEG oko-lavamaty 88730 washing machine error codes
    Peej,
    It usually means that the ‘Flood Protection Device’ has been activated and the noise you may be refering to is the alarm sound (buzzer) in the Control Panel warning you of this. 🙁
    It’s likely there is an internal leak causing the device to trip OR that the pump is at fault in some way. Both can give the same Error Code C3 and I would advise you to unplug the machine then carry out an inspection of the Pump/Filter Unit to see if it is blocked or restricted 😉
    Your Instruction Booklet will explain further 🙂
