Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › AEG OKO_Lavamat 6100 digitronic
- This topic has 8 replies, 2 voices, and was last updated 8 years, 9 months ago by
AEGowner.
June 12, 2017 at 10:24 am #91430
AEGowner
ParticipantE-Nr.605.648 372 F-Nr.094295696
Hi, my trusty old AEG OKO_Lavamat 6100 digitronic washing machine seems to be leaking from underneath the rear left side as you face the machine. Is it likely to be something simple like a loose jubilee clip in that area that I could repair myself if I took the back off, or should I call an engineer? 😕
June 12, 2017 at 10:27 am #448058electrofix
ModeratorRe: AEG OKO_Lavamat 6100 digitronic
until you take the top off, run the machine and trace the leak you are not going to know if you can fix it
with leaks it can come from anywhere. the leak could be at the front but run round inside the machine till it drips out the rear. all depends how level your floor isDave
June 12, 2017 at 11:24 am #448059AEGowner
ParticipantRe: AEG OKO_Lavamat 6100 digitronic
Thank you for your reply Dave. I have taken the back off and can see it is wet underneath a part towards the front of the machine on the rhs looking from the back. I have taken a photograph of it, but can’t see how to upload it 🙁
June 12, 2017 at 12:24 pm #448060electrofix
when you click quick reply go to full editor and lower down the screen is an option to upload a file
June 12, 2017 at 12:43 pm #448061AEGowner
Thanks again. Here is the pic (I hope!) 😀
June 12, 2017 at 1:14 pm #448062electrofix
wow thats an old type of pump
these pumps have a water seal that wears and starts to leak. If its dripping it needs to be replaced
on the one i looked up
Gen part
https://shop.ukwhitegoods.co.uk/8996454 … drain-pumpor
no gen partJune 12, 2017 at 2:36 pm #448063AEGowner
Thanks Dave. Yes, it’s 22 years old! 😛 Just working out whether it’s worth repairing…. Is there much difference in quality or would the no gen part be good enough, and how long should it take an engineer to replace it?
June 13, 2017 at 1:07 pm #448064electrofix
the no gens are not too bad and judging by the price of the gen you could buy about 3 non gens.
also at 22 years old you do not expect another 22 years so if you got 8 years out of a non gen that makes the machine 30Dave
June 13, 2017 at 1:28 pm #448065AEGowner
Thanks for your help and advice Dave 🙂
