AEG oven cooling fan not coming on
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries AEG oven cooling fan not coming on
  • #96289
    boselecta
    AEG double oven
    DC7003000M
    pnc; 944171535
    sn; 12407522
    (This is the non ZN blue wire thermal limiter double oven range).
    The top oven cooling fan is not coming on and the fascia controls are getting very hot.
    I incorrectly replaced the cooling fan as it was noisy and the shaft seemed loose.
    The same thing is still happening.
    There does not appear to be a cooling fan cut in thermostat only mainand top oven thermostat.
    I don’t know if the cooling fan is meant to come on via the pcb when it reaches a certain temperature?.
    Also there is a relay for the top and bottom oven which Could be at fault.
    Has anyone else had this problem with this range of AEG double oven cooling fans?
    #462915
    have emailed the tech info
