AEG Oven Cutting Out during cooking (grill & oven)
Home Forums Public Support Forums Help And Support Cooker And Oven Forum AEG Oven Cutting Out during cooking (grill & oven)
  • #15970
    turnerrf
    Can anyone help or provide any guidance. I have an AEG oven and hob and its circa 2 years old. In the last few days either oven or grill has stopped midway through cooking but will restart after 15-20 minutes. I presume that somewhere its overheating and is cutting out as a precaution. It then restarts after its cooled down.
    Is this feasible and is there anything I can do to avoid this happening (obviously I’m happy that it cuts out before overheating) but not evry time we want to cook something.
    Any thoughts, views etc welcome in this respect.
    Ronnie
    #167029
    Re: AEG Oven Cutting Out during cooking (grill & oven)
    hi
    the probable cause may be due to the cooling fan failing which will in turn allow the oven cabinet to overheat and cut off.
    this will require an engineer to put right if this is the case.
    the symptoms that you are giving leads 75{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} into this area.
    bryan
    #167030
    Dave_Conway
    It’ll be the thermal cut out unit more than likely, this thread explains it pretty much:
    http://www.ukwhitegoods.co.uk/modules.p … pic&t=4874
