aeg oven d8804-4m
  • #70316
    kwaremont
    hi this oven overheats , but when the customer turns it off the fan stops but the element stays on , and has to be turned off at the wall, as this has electronic control could this be the PCB rather than the thermostat, thanks
    #377785
    Re: aeg oven d8804-4m
    if the element stays on then my next step would be to check the relay on the pcb for short circuit
    cheap easy repair if it is
