‘Morning All,
What do you think this could be please?
Turning the temperature dial from “off” to any temperature causes the oven to cut out. Can repeat with same fault each time.
I’m finding that after restoring power I can select different functions, however each time I turn the temperature dial the result is the same – power cuts out.
Does seem like I cleaned it and now it doesn’t work!
PNC 944 185 704 00 3,5kW
It has a properly rated cable direct to the consumer unit. Have meter, can test! Searching archives, but any comment appreciated. Thanks.
Simon
