Hi all, I have an AEG oven (model no. B4101-5-M), it is cutting out after 10mins, the front panel feels very hot. Previous posts suggest the ZN limiter might be the culprit, but even using the photos on this site, there doesn’t seem to be one in my oven. My model is listed on the page for this part, so it must have one. I’ve photoed the oven inner, so you can hopefully point me on the right direction. Many thanks!
Other numbers are
PNC 944 181 198 03
Typ. : 91 ACD 01 GA
S No 10661814.
Fan doesn’t work at all when I select fan on the selector knob. But when I switch the oven off by the mains wall switch and then on again, the fan turns briefly for a second.
one of the contacts on the selector switch feed back to the clock to tell it the oven has been switched on. It is the clock that controls the fan and allows it to run on for a time after switch off
so its either a faulty selector switch or a faulty clock
