Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › AEG OVEN NO CLOCK DISPLAY DS701-4-A
- This topic has 6 replies, 3 voices, and was last updated 14 years, 9 months ago by
colly.
June 22, 2011 at 10:19 pm #63543
colly
ParticipantHi guys
Been to a call today where customers say’s oven is not coming on
Looked to find upper oven and grill is working fine
Dgital clock / controller has no display
Checked out all toc’s they were ok
Seem’s to be pcb not feeding clock
Any one any other guesses ??
Dstri out of pcb as is connect price £93 plus vat
Cheers
Colly
June 23, 2011 at 7:16 am #354077Martin
ParticipantRe: AEG OVEN NO CLOCK DISPLAY DS701-4-A
What’s the PNC number?
June 23, 2011 at 9:44 am #354078electrofix
ModeratorRe: AEG OVEN NO CLOCK DISPLAY DS701-4-A
assume model is D5701-4a
from diag there is a clock module and power board
it could be either or both
the power board has the relays on it to control elements but will also provide a low voltage to power the clock display and electronics to set temp
it is either this power board not supplying power ( look for blown caps etc) or the clock board blown
the top oven seems to be a conventional stat so will not be affected
hope it helps
DaveJune 23, 2011 at 9:41 pm #354079colly
Martin wrote:What’s the PNC number?
944171273
June 23, 2011 at 9:47 pm #354080colly
Hi dave
cannot see any wrong with power module caps dry joints etcI have not inspected clock pcb
As for top oven / grill you can remove all wires from power board and these will still operate fine.
Power board is just for the main oven.
Clock is an obsolete part even though oven is just over 5 years old .
No one seems to have board in stock not even disrti
Cheers
Colin
June 24, 2011 at 9:27 am #354081electrofix
you need to have a close look at the board to try to find the power supply
it can be a transformer , series capacitor or switch modeif its a transformer you can check primary and secondary windings for continuity, series capacitor are cheap so if its that change it and see. switch mode is more difficult
you could send me a good quality photo of the board and i will look to give you some pointers if you like
June 25, 2011 at 9:59 pm #354082colly
Hi dave
It is a transformer on pcbi will check it for continuity
Cheers
Colin
