AEG oven not working correctly.
Home Forums Public Support Forums Help And Support Cooker And Oven Forum AEG oven not working correctly.
Viewing 11 posts - 16 through 26 (of 26 total)
  • #448087
    HTSteve
    Re: AEG oven not working correctly.
    It is this thing: https://shop.ukwhitegoods.co.uk/8996619 … an-control
    I’m not getting the same problem as that page says I would if it was gone but it is definitely burnt looking on the rubbery part.
    #448088
    HTSteve
    This thing is burnt: http://i.imgur.com/dQTwmLi.jpg
    The selector switch looks ok from the outside but maybe it could be faulty as you said.
    Here’s an image of the selector switch:
    http://imgur.com/a/gAZcx
    #448089
    that blue thing is the relay that starts the cooling fan. if that fails oven will start ok but cutout after 10 minutes or so
    HTSteve
    So the problem can only be the switching control or the overheat stat. Where might I locate the overheat stat button?
    #448091
    the overheat stat will be on the top of the oven near the fan assembly. its normally designed to cut the oven out if the fan does not start
    HTSteve
    Found it. How would I know if it has been tripped?
    #448093
    join the wires together. link them, make sure things cant touch and turn oven on to test. if it goes look to replacing the blue burnt relay as well
    HTSteve
    Thankyou
    #448095
    HTSteve
    Have done all of that and still the exact same problem. I have noticed that the Zn limiter is very very burnt and one wire has disconnected. Is there a way to bypass it to see if that is the problem? I have two blue and two white wires going into the Zn limiter. The whites have come disconnected
    #448096
    the small blue rubbery thing operates the cooling fan. if that was faulty oven would heat normally for about 10 mins then cut out
    HTSteve
    It disintegrated in my hand. I tried bypassing it but same problem persists. Maybe the temperature dial is faulty? The only things left are the temp dial and the selector dial. The selector dial seems to work ok by looking at the left led. Might just have to get a new oven because I’ve tried everything now. Sigh. Thanks for all of the help dave
