aeg oven wont heat up
Home Forums Public Support Forums Help And Support Cooker And Oven Forum aeg oven wont heat up
  • #60831
    karlosmaximos68
    hi this a AEG 91AHB O1GA,the oven wont heat up at all,could it be the oven element?
    thanks
    #343821
    Re: aeg oven wont heat up
    Moved you to correct forum. 😉
    It could be the element, it could also be the oven thermostat or the selector control.
    The only way to proceed is to isolate the cooker from the mains and test the element with a megger or suitable multimeter.
    You should not assume the element is faulty without first testing it.
