AEG Pnc 91123254205 (dishwasher)
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries AEG Pnc 91123254205 (dishwasher)
  • #31436
    rocker
    Customer tells me the machines has been running all night, the led timer read out is flashing (dot30) and programe light is flashing and a rumbling noise possible (pump)
    can anyone please advise me what to look for,and could this be a pcb fault.
    cheers John.
    #231188
    senseib
    Re: AEG Pnc 91123254205 (dishwasher)
    Water in base maybe? or perhaps a blocked drain pump?
    #231189
    rocker
    senseib, thanks for advice will check this out. John
    #231190
    whitevanman
    check valve, metering tank, rinse aid qty, powercut if no water in base, spray arms blocked.
    Hope this helps
    Wvm
    #231191
    rocker
    Wvm. Cheers for advice will check. John
    #231192
    rocker
    called today found side tank partially blocked,as fill tube.cleared and now ok.
    thanks for help. John
