AEG pro intensiv dishwasher HELP!
Home Forums Public Support Forums Help And Support Dishwasher Help Forum AEG pro intensiv dishwasher HELP!
  • #100938
    Matt.sell
    Dishwasher is stuck on the first drain cycle of the program, the machine is empty of water after a short while the machine beeps twice and stops.
    I’ve checked there are no blocks or kinks in the drainage hose, no blocks in the filter and there is no water in the anit flood device underneath.
    the water pump works fine and I’ve checked the resistance across the terminals all seems perfectly fine. I just can’t think of anything else that would stop the machine moving to the next part of the cycle.
    Please help!
    #482755
    have you got a model and pnc number ?
    Matt.sell
    Pnc 91153911400 Pro intensiv favorit 34502vio
    #482757
    some of the range of these dishwashers are subject to a modification due to the pressure sw blocking up over time
    would need to see pics of various part of the machine to determine. the first one needs to be inside the bottom of the machine with the filter taken out
    you would need to host pics offsite due to server size constraints
    Matt.sell
    Hi Dave
    have you got a email I can send them onto you?
    Did you want a pic of the turbidity sensor?
    Matt
    #482759
    its not a turbidity sensor problem at least i dont think so
    there is an air operated switch that detects water height. this sw was found to block up with goo over time and the mod is designed to stop that or at least reduce it
    would be no where near my work email till monday but you can upload pic to something like google pic and then post a public link on here that anyone can access
    the pic below is noe of the things i am looking for so you can check yourself
    Matt.sell
    Hi Dave,
    you Sir are a legend!
    I used a cotton bud and cleaned the hole you pointed at, Dishwasher is working perfectly.
    Thank you
    Matt
    #482761
    ok that means at sometime it needs a mod kit that is meant to stop it blocking
    https://shop.ukwhitegoods.co.uk/4055…ure-sensor-kit
    It will then look like below
