AEG Protex+ washer dryer
Home Forums Public Support Forums Help And Support Washing Machine Help Forum AEG Protex+ washer dryer
  • #99530
    andyjawa
    AEG L87696wd. 914604701/00. Fault code E10. This code had come up on arrival machine spun and pumped out: I set the machine on rinses with same load and then to spin to the end door can be opened no error code came up. I think this E10 has something to do with filling rather than a problem with pump out since that constantly showed no sign of a pump problem. Noticed on the AEG spares site picture this valve is one of those wretched speed flow sensor types so could maybe be that although like I said the machine did not go wrong at the time of my test. Could be a pin prick hole in the pressure switch rubber hose I suppose but the water level looked right. Trouble is this contraption is on a plinth 2.5 feet off the ground and is boxed in – another one of those daft characters going all out for tweeness rather than practicalities. What you reckon? On the right track? Any other pointers please. Thx.
    #476769
    the E1 series codes are E11, 12 and 13. All the user sees is E10 and the actual code is only visible in service mode
    below is a list of codes and possible causes
    andyjawa
    Ahh, great and thx I`m on the right track at least! Will have a look and see what whats.
    #476771
    andyjawa
    Dryer solenoid was open circuit. Thx.
