AEG B5741-5-m pnc 94418121700. Looking for advice please from anyone with experience on these pyro ovens. As soon as oven is turned on the cooling fan comes on and within couple of seconds e04 appears(temp range of oven sensor exceeded) will also lock door sometimes. Checked temp sensor and getting a reading of approx 530ohms. Meggered elements and checked all stats. Had the benefit of this having a twin unit beside it which i cross referenced readings. I presume the board replacement is now the correct option. Also does anyone have a part no for module.Thank you.
