AEG S/O B4140D
Viewing 1 post (of 1 total)
  • #40802
    Steven
    AEG Pyro Oven B4140D (944181384)
    Cutting out when in use, have checked all the obvious the cooling fan runs, cut in and cut out appear to work over heat stat ok, no shorts, all elements ok, main fan motor ok.
    When it Gets hot (not to temp) then you hear a chattering noise from the door lock it then shuts down altogether. Initally would not come back on until it cooled down, now it not working at all.
    Not much on this oven except the main pcb at the rear.
    Any ideas welcome
    Steven
