AEG S756281KGS
  • #48943
    don1407
    Product code 925010120003
    The fault is no light & not cooling. There is an “E” in freezer display & “F” in fridge display. IF you press the power button you get “OF” in both displays light comes on & compressor runs. I suspect it may be a evap fan fault as fan does not run even after evap frozen.
    Also is there only the pcb inside fridge? or is there another one? Did have a look at back but in tight spot on copper pipe so did not go too far, but did notice something on side of compressor.
    Any advise or information please.
    Thanks in advance
    Ian
    #298259
    TheSpinDoctor
    Re: AEG S756281KGS
    That is the fault code for a faulty evaporator ventilator (fan). There are 2 PCB’s in the dispenser unit, one under the product & one in the fridge.
    #298260
    don1407
    Re: AEG S756281KGS
    Thanks for the reply Spin Doctor. So is it normal when showing fault code for appliance to turn interior lamp off & compressor only to run when you press power button? or is there likely to be something else other than the fan?
    The PCB’S i have found the one in fridge, did not check in dispenser and one under product is that behind bottom grill?
    Sorry for all the questions but want as much info for when I return.
    Thanks again
    Ian
    #298261
    TheSpinDoctor
    Re: AEG S756281KGS
    I have to be honest, that is not something I have encountered myself so cannot answer if that is normal or not. Sorry I can’t help on that one.
    Yes the bottom board is under the front grille.
