Hi there,
Looking at prev posts i think the fridge sensor is faulty.
the display is showing a small square.
Prod number 924853681.
Can you pls give the part number and where to fit.
Thanks a lot
msappliance wrote:Hi there,
If the top part of the display is showing the “small square” you mention then the Evaporator Sensor (Part No 2080544014) is the likely culprit? (Located on the evaporator I would think?. :wink:)
