Home › Forums › Public Support Forums › Help And Support › Fridge And Freezer Forum › aeg santo 75348-kg fridgefreezer
- This topic has 9 replies, 3 voices, and was last updated 11 years, 6 months ago by
Rob69.
October 7, 2014 at 1:16 pm #82511
Rob69
Participantthe fridge is not cooling could it be the thermostat or more serious
October 7, 2014 at 1:53 pm #420093kwatt
KeymasterRe: aeg santo 75348-kg fridgefreezer
There is absolutely no info on that model at all which leaves me two answers to give…
To find it, if it’s less than about 10-12 years old, I’d need the product number from the rating plate to have a look.
Or, if it’s older than that it’s almost certain to be obsolete with no parts available any longer and that being the case, it’s probably not worth doing much with.
October 7, 2014 at 3:04 pm #420094Rob69
ParticipantRe: aeg santo 75348-kg fridgefreezer
no problem its 928405238,it may be 8 years old
October 7, 2014 at 3:11 pm #420095kwatt
From what I can see, last produced in week 12 2005. 😉
It’s frost free and draws cold air from the freezer into the fridge to chill it.
If can be any one of a number of things that are wrong, temperature regulator, sensors, fan, a blockage in the airways and compressor are all possibilities I’m afraid.
The most likely I would think are the regulator inside at the back of the fridge behind the rear cover or the fan motor. But, you’d need to try to determine which was the issue as those are just best guesses based on the design.
October 7, 2014 at 3:27 pm #420096Rob69
ok cheers but every thing seems to be in the freezer department,apart from the thermostat at the top where the light is
October 7, 2014 at 3:30 pm #420097kwatt
You mean this….
http://shop.ukwhitegoods.co.uk/21462820 … thermostat
October 7, 2014 at 3:30 pm #420098SAMURI
The most common problem is the defrost system on this model.
It can be the heater, or heater NTC’S or both not a cheap repair.
The first thing to try is a full defrost.
Get someone to look after your food and turn it off with the doors open for 48 hours.
Check to see if any water is in the compressor tray after and check the rubber none return valve above the compressor tray is not stuck together.
When you turn it back on it should return to normal in 4 to 6 hours.
Then keep a check on the date to see how long it is before the problem returns.
If it returns in three to four weeks it will be a fault on the defrost system and as it is 8 years old it may not pay to have it repaired due to the cost of the parts.
Bob
October 7, 2014 at 3:49 pm #420099Rob69
thanks for the help but its not the part that i’m looking at it’s a long tube type of thing,that connects to the temp control
October 7, 2014 at 3:53 pm #420100kwatt
If it’s 256 on the diagram, that won’t be the problem unless it’s been physically damaged.
October 7, 2014 at 4:11 pm #420101Rob69
ok thanks again for the help
