Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › aeg santo 75388
- This topic has 7 replies, 3 voices, and was last updated 11 years, 7 months ago by
dpr1974.
September 5, 2014 at 8:34 pm #82112
dpr1974
Participantusual problem of the evaporator icing up, the defrost heater is working however. i assume that if the heater is working then i am looking at a pcb problem? thanks in advance.
David
September 6, 2014 at 10:28 am #418736SAMURI
ParticipantRe: aeg santo 75388
Is it ice or a white frost.
If it is ice then the drain N/R/V above the compressor may be stuck so the water cannot drain away.
If it is white frost then it is normally the heater or heater stat faulty.
It is rare to have a problem with the main PCB on an AEG.
Bob
September 6, 2014 at 5:46 pm #418737dpr1974
Hi Bob, sorry i forgot to say it was the white frost type. where is the heater stat located and would you have a wiring diagram for this model?
cheers
September 6, 2014 at 5:58 pm #418738Martin
There are 45 different AEG Santo 75388’s so the PNC number would help to get the correct wiring diagram you need. 😉
September 6, 2014 at 8:03 pm #418739SAMURI
As Martin said the santo covers a large range of models so you need the correct model PNC number.
The heater stats are normally on the rear of the evaporator but have different temperature settings depending on the PNC number.
It can also be an intermittent fan fault where the fan sometimes stops working then the appliance just keeps running and does not go into defrost as it try’s to maintain the temperature in the freezer.
Bob
September 8, 2014 at 8:30 pm #418740dpr1974
The pnc is 928405953-01. i’ve eliminated the fan as a cause already Bob. 45 versions? bloody hell, i knew there were a few because i’m looking for a freezer draw too and it took a while to find the correct one, then it’s £30 odd quid for the draw and another £30 quid for the front :O
David
September 9, 2014 at 8:08 am #418741SAMURI
The NTC sensors plug in inside the freezer and fit to the evaporator.
If the defrost heater checks out ok then it is most likely the sensors.
They come as a pair and are attached to a plug that just plugs in.
Bob
September 11, 2014 at 6:20 am #418742dpr1974
Thanks Bob.
