3388 8kg PNC924519321. This F/F is freezing things in the fridge. It has 2 compressors and an evaporator plate at back of fridge. Im thinking its just a sensor problem and have discovered it has 2 in fridge. One described as 2120mm and the other 2200mm. The fridge display is showing a 0 in top right side, is this the error code for the sensor involved or something else maybe? When i got there the fridge had just cut out and the plate was frosted so the sensor seems to be working but out of calibration. The sensors are very cheap so i could change both. Any help please?
Subs
