AEG Santo S75358 KG3 PNC925034005-00
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries AEG Santo S75358 KG3 PNC925034005-00
  • #42444
    bagman
    Frost Free F/Fzr, not cooling in the fridge at all, freezer evap icing up normally. (Cust has done a 48hr defrost and reset).
    I’m assuming a PCB fault here, but there’s 3 of them. One is a display PCB but the other two look like they interconnect.
    Anyone give me a heads up before I order an expensive mistake?
    #273513
    Try to look and check if dumper is working… he must be open when compressor is working and closed when compressor stops or reach desired temperature..
    #273514
    Johnnyboy
    Re: AEG Santo S75358 KG3 PNC925034005-00
    Sorry for hijacking this thread but I have the same fault, I was wondering if the fan in the freezer can be forced on via panel? Either faulty pcb not telling fan to come on or faulty fan?
    Not unknown to be barking up the wrong tree though.
    #273515
    Johnnyboy wrote:I was wondering if the fan in the freezer can be forced on via panel?
    Isn’t any info about service mode on this model 😥 …
    Johnnyboy wrote:Either faulty pcb not telling fan to come on or faulty fan?
    After couple of minutes compressor starts…reasons for fan not starting:
    1) one or both doors aren’t closed (or Pcb isn’t reading that/ magnetic read relee )
    2) freezer temperature sensor isn’t working
    3) Fan damaged or his wires/couplings
    4) main PCB
    #273516
    Simon46
    Ive got one the same. Any common fault info on this?
    S.
    #273517
    Johnnyboy
    I replaced the switch on the door of the freezer and the fan, aint been back (yet)
    Cheers Johnnyboy
