Aeg santo s83200cmw0 problem…
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Aeg santo s83200cmw0 problem…
  • #97906
    Spyker
    Hi. I have good fridge, but something wrong happening. Where to search problem/problems? How much can cost repair/fix of the fridge? If it’s expensive better search a new one? New fridge recommendations? Where I can find repair, or disasembly manual? Do I fix it by myself? I add a photo of a problem:
    https://imgur.com/a/NoRlgsh
    #470068
    start by doing a complete defrost, switch off, door open for 2 days
    then take it from there.
    check the door seals look ok
    may be a blocked drain hole ot a defrost heater failure
    dave
    #470069
    Spyker
    Thank you so much. Seals looks okay. Drain hole also checked. Freezer looks okay, no condensating, or ice freezing inside. Problem with fridge. Cooling well, in fridge and freezer, but fridge condensating, and building ice in photo. There can be more problems if i change defrost heater? Like sensors, or fans and etc…
    #470070
    well when you close the door of the fridge there is only so much condenstion inside. if its getting that bad quickly the air must be getting in
    Spyker
    I think, im gonna buy new fridge. Maybe somebody can recommend something? Now i’m looking for similar electrolux fridge. Which is better en3601mox or en3613mox? Also you can recommend other brands and models up to 400$
