AEG side holder
  • #102482
    ColinM
    Hi All,
    I have an AEG KMK561000M microwave combo-oven. behind the grid supports for the trays one of the holders has a melted and makes a flash over point for when the microwave is being used. I have ordered a replacement part and it’s on its way but before I started to push and pull this unit. I thought it’s best to ask if anyone knows how to fit this?
    I looked at the other 3 holders and they seem solid in position but for some reason this one has been loose
    thanks
    Colin
    #489085
    cant see this part on the oven parts listing but there are 11 ovens with the same model. would need Pnc number to tie it to one
    chances are when part arrives it should give you a clue how it fits
    ColinM
    Thanks for your response
    hopefully it will be simple to fit… I just don’t want to break anything hence my question
    #489087
    ColinM wrote:Thanks for your response
    since its all heat proof it will be metal and hard to break. the only thing is insulation which you may carefully have to move and put back
    ColinM
    hi there I need to remove the oven shelf support pivot to insert it through the new grid support, how do you remove this?
    #489089
    no idea without seeing one close to
    there is no technical manual on these
    have you checked the user manual
    RachelInouye
    Blocked
    Hi Colin! It’s great that you’ve ordered a replacement part for your AEG KMK561000M.
