model 64800w pnc 911786005/01
cust reports intermittant no go… on/off switch ok, mains light every time. programme indicator only shows feint lights. progress lights dim. prog selector only bleeps on pre-wash when pressed. is it likely to be the programme selector board? mains plugged into 2gang extention board
richard
forgive me if i’m wrong.
i’ve had a few lux group dishwashers lately where the transformer on the circuit board has burnt out. you can solder in another which is about four quid from r.s. or i’ve also pinched one from a recent indesit washer board.
in each case the transformer was visibly over heated.
