AEG Super silent plus L76650 – NDA
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries AEG Super silent plus L76650 – NDA
  • #54111
    neon_3SP_glow
    No obvious defects on the 5 terminal motor. And no obvious defects on the Inverter board (impressive heat sink jobbie).
    My instincts tell me it is the motor, I have not had much XP with these AEG super silent motors. Do they often go wrong, and is there an easy way to test if the windings are all as they should be?
    The customer spent over (gasp!!) £600 on the product and it’s only 14ish months old.
    #318440
    neon_3SP_glow
    Re: AEG Super silent plus 76650 – NDA
    The induction three-phase motor mounted on EWM3000NEW, EWM25… and EWM35… appliances is powered by an “INVERTER” board, which has the function of converting the single-phase voltage to a three-phase
    voltage.
    #318441
    bigchrisoioi
    Re: AEG Super silent plus L76650 – NDA
    whats the fault?…whats the diagnostic code?……if you are working on this model, do not touch that invertor at least 30 mins after last use/test as that thing will discharge high voltage on you!!!!!!!…can you give us more info on what the fault/diagonstic code is???…..chris
    #318442
    neon_3SP_glow
    Hey, thanks for the advice there Chris. I was not aware of the danger. Luckily I didn’t get a shock.
    Not sure how to access the diagnostics on this… Guessing now it is like any other Zannussi type.
    No fault code has been shown as far as I am aware, but the motor refuses to turn. I will take another look this week and report any further findings/developments.
    #318443
    bigchrisoioi
    no motor action is most likely that invertor board, costly little devils as well!!!!!good luck , and wear rubber gloves and use insulated pliers !!! lol
    #318444
    neon_3SP_glow wrote:I will take another look this week and report any further findings/developments.
    The testing procedures on these beasts is rather different from their single phase cousins. If you would like some additional tech info then do please let me have your email details.
    #318445
    neon_3SP_glow
    my e-mail address is…. gunner_3SP_frank@yahoo.com
    that would be great Martin thanks.
    #318446
    It’s a 5mb pdf file on it’s way to you! (Hope you got room in your box?:D)
    #318447
    neon_3SP_glow
    Martin wrote:It’s a 5mb pdf file on it’s way to you! (Hope you got room in your box?:D)
    Many thanks Martin, I now have the pdf. Scheduled to re-call on wednesday, I will try to update the post with my findings! once again, many thanks.
    #318448
    neon_3SP_glow
    srry for the late reply. The diagnostics said it was main PCB to blame, fitted new PCB on control panel and worked fine 😀
    many thanks guys.
