aeg t356850 prod916095202 00
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries aeg t356850 prod916095202 00
  • #90541
    HotDog
    This dryer will run for about 2minutes clockwise then cuts out,if you open the door and press start it will run for another 2 minutes i am thinking door switch fault rather than module anyone had same problem
    #445155
    Re: aeg t356850 prod916095202 00
    does it cut out or is it failing to reverse. bought an AEG of Ebay last year with similar fault ended up being bad relay solder joint on pcb
    HotDog
    it cuts out without reversing i dont know if it would have reversed due to the lack of tme before it cut out
    #445157
    have pm’ed you the tech info
    hope it helps
    HotDog
    thanks dave
