Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Aeg T560 tumble dryer lift pump make noise and low heat?
- This topic has 9 replies, 3 voices, and was last updated 15 years, 11 months ago by
vito.
April 19, 2010 at 6:18 pm #54066
vito
ParticipantThere is magnetic lift pump and that makes noise sometimes. I open it and i can pull wheel out, is there some possibilities lubricate that, and if its okay where i put it?
AEG LAVATHERM T560
April 19, 2010 at 6:32 pm #318256iadom
ModeratorRe: Aeg Lavatherm T560 tumble dryer lift pump make noise
This type of pump usually makes a noise when worn, replacement is the only long term cure.
April 19, 2010 at 6:54 pm #318257vito
ParticipantRe: Aeg Lavatherm T560 tumble dryer lift pump make noise
It looks in eye very good, is that magnetic worn what makes it?
April 19, 2010 at 7:42 pm #318258iadom
Normally you will find the impellor moves from side to side a little if it is worn.
April 19, 2010 at 7:59 pm #318259vito
Okay thanks.
Another question is, i think there is too little heat in my machine, i found 2 thermal fuses one in the heating element and another, is in exhaust pipe is it possible that another one those fuses is broken, and thats why theres no normal heat?
Dryer get warm, but i think its half that normal heat?
Also heating element is twin model, so i check it that fast when dryer was on, and only one of those heaters get heat.
April 19, 2010 at 9:27 pm #318260iadom
Its not a machine that I am familiar with to tell the truth. If there is a High/Low heat switch then that could be at fault. :con:
April 19, 2010 at 9:36 pm #318261vito
Here is picture, this is exactly same heating element and only those 2 heater get heat.
http://www.aijaa.com/v.php?i=6092858.jpg
And this the machine AEG T560
April 19, 2010 at 11:07 pm #318262Penguin45
ParticipantRe: Aeg T560 tumble dryer lift pump make noise and low heat?
Heater is damaged, new one is part number 1120990-76/5.
If the pump is noisy or intermittent, water may be thrown into the heater, so the pump must be replaced as well – part number 8996474080-86/9.Penguin45.
April 20, 2010 at 10:43 am #318263vito
I found it another heater element, where is same 2 heater damaged, im thinking can i replace them together, so i have one working element?
i answer my own question, its impossible.
April 20, 2010 at 6:42 pm #318264vito
Is there any possibilities that pcb board error makes only 2 heater heat?
