AEG T58900
  • #77786
    franz
    This t/dryer runs for about a minute then fault code E50 appears, anyone know what this means.
    Thanks Franz
    #403397
    Re: AEG T58900
    e50 faults are all about motor
    E51 motor triac
    e52 motor thermal cutoff
    e53 motor triac sensing failure
    e54 motor jammed
    you are seeing the cutomer code of E50 to see actual code you need to get into engineering mode ( have no info how to on this dryer )
    suggest you look for motor shorts to earth first, motor getting wet will give you an E51
    franz
    Re: AEG T58900
    Thanks Dave,
    Anyone know how to get into diagnostic mode?
    Franz
    #403399
    Re: AEG T58900
    franz wrote:Anyone know how to get into diagnostic mode?
    Sure, here you go……..
    Position 11 gives you the last error code recorded. 😀
