AEG T65170AV (916095259) Dryer Beep Codes?
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries AEG T65170AV (916095259) Dryer Beep Codes?
  • #98685
    jontymox
    Good evening all,
    Wondering if anyone could shed some light on a problem with the above tumble dryer?
    Evidently, when a programme is selected, and the start button pressed, the start/pause button flashes red (normal) but quickly changes to a flashing yellow led, and beeps three times.
    The Drying, Cooling & End lights also illuminate, but no machine action.
    I’m due to visit early next week, and as the customer lives in a remote area a long way away, it would be good to have some info,’ or at least have some idea what the above relates to.
    jonty
    #473374
    check your email
    dave
    #473375
    jontymox
    Thanks again Dave for the info’
    Will hopefully locate the problem on Tuesday.
    jonty
    #473376
    jontymox
    Have had a look at the dryer now, and struggling to find the cause of the above.
    Tried to enter diagnostic mode without any success, as I think it’s more for the dryers with a display.
    Also tested door microswitch, as I thought it may be that, as it doesn’t start or tumble etc.
    It would be good to know if/what the 3 beeps denote, together with the start/pause button flashing amber as I can’t find such information…
    jonty
    #473377
    codes on these are the flasing of the start light between red and green
    if three beeps mean series 3 faults that makes it a conductivity fault
    see the aeg manual page 30
    jontymox
    Agreed, May be a conductivity fault, Dave.
    However, problem manifests itself by red and amber… do you mean green?
    Evidently, this dryer has barley been used in just over 2 years, as it’s a back up, so fault should be “simple to diagnose.”#
    jonty
    #473379
    jontymox
    “barley” should read barely!
    #473380
    does not mention yellow so i think i would assume yellow is a weak green and see where it takes you
    if the red led and the green one mix you get yellow
    normally in fault code you get a mix of flashes like 3 red followed by 2 green and repeat
    something really odd the way this one is acting. try having another go at diagnostics, i see in this one you have to turn it on first then press buttons when normally you press buttons then turn on
    long shot have you checked door switch ?
    jontymox
    Well, I had another look at the door microswitch, and wiring multiplug… re-fitted, and lo and behold all fine!
    I imagine the above would also account for problems progressing diagnostic mode.
    Thanks again,
    jonty
    #473383
    jontymox
    Blast!
    Customer just called to say fault has recurred…
    It was fine for ten days, but now original fault back.
    I recall door switch Ohms resistance good, and having nipped up and re-fitted multi plug connection, all good.
    Will check wiring harness from the above to board, although suspect faulty board now due to intermittent nature of fault.
    jonty
    #473384
    jontymox
    Well, I’ve checked the wiring harness as best as possible, and have decided the fault lies in the board.
    Customer now mulling over whether or not to invest in over £110 in the above.
    jonty
