Hello, this looks like a useful forum, glad to have found it!
My AEG dryer model T88595is won’t power on. It was functioning fine until last weekend and randomly worked again last night.
It had a new motor about 2 years ago and it’s a good machine when it works! Would like to save it from the tip if possible…any thoughts on what could be stopping it turning on?
first thought is always the socket
after that i tend to check the board power supplies
one of the probems with later mahines is they are not off but are in standby. this means power supply components can fail even if its not in use at the time
Probably one half of the double socket is nuked no harm in visually having a damn good look with the power off!. Pretty common with tumble dryers used to get this a lot and the actual plug doesn`t always give you a clue to that either.
