AEG trips electrics
  • #21596
    medion
    My AEG Favorit 445i dishwasher trips the fuse in the mains box when it gets to a certain point in the wash cycle, if I reset the switch the anti-flood device kicks in ( ie the pump works continualy). If I then pull the dishwasher from under the worktop and without actualy doing anything just push it back again it will work normaly for a few wash’s before it trips again. Any advice welcome, Thanks.
    #191814
    cab
    Re: AEG trips electrics
    could be a few things thats causing the leak into the base, but the water in the base is most certainly getting into the wash motor causing the trip to go.
    leak could be from drain pump, wash motor or side tank.
    my advice would be to get an engineer to check it out.
    cab
    #191815
    gegsy
    If you are going to investigate yourself medion, please unplug appliance before proceeding :plug:
