AEG W/D E20 FAULT Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › AEG W/D E20 FAULT This topic has 3 replies, 3 voices, and was last updated 19 years, 5 months ago by HEADSTAND. Viewing 4 posts - 1 through 4 (of 4 total) Author Posts November 9, 2006 at 8:24 pm #22421 HEADSTANDParticipant Can anyone help customer says E20 fault showing on dry ???????? November 9, 2006 at 8:34 pm #194887 FlymanParticipant Re: AEG W/D E20 FAULT Zanussi error code so problem with the drain pump. If it is only coming up on the dry cycle it might be a restricted or extended drain hose so the pump is cutting out on its overheat cut-out November 9, 2006 at 8:35 pm #194888 Penguin45Participant Re: AEG W/D E20 FAULT http://www.ukwhitegoods.co.uk/modules.p … 0&start=45 Post 2#, P4. Chris. November 9, 2006 at 8:46 pm #194889 HEADSTANDParticipant Re: AEG W/D E20 FAULT Cheers many thanks 4 the swift reply Author Posts Viewing 4 posts - 1 through 4 (of 4 total) You must be logged in to reply to this topic. Log In Username: Password: Keep me signed in Log In
