aeg w/dryerl16830 enr 914602122
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries aeg w/dryerl16830 enr 914602122
  • #55982
    adv
    went to this day. not heat on dryer. heaters ok and reset state ok and other state . got pot state at front, which reads 6.28k ohms, am getin no neutral to heaters any tips lads. have changed pot state at front on older models dont no bowt this one. washes fine. help? 😆
    #325816
    Re: aeg w/dryerl16830 enr 914602122
    Maybe it has one of those thermistors in a hose in the base down the bottom of the condenser where the two thin (orange?) wires break?
    Or what about water flow / green solenoid? Tech data should be available on Connect mediator.
    Mike.
    #325817
    adv
    water flow fine.you wires in hose were is that would that stop in dryin with no fault code ?
    #325818
    Mike refers to the NTC wires going to the bottom hose of the condenser. They break away from the connector due to the wires cable-tied to the condenser being too short. Reconnect the broken wire using AMP tags onto the NTC and ensure more slack on the wires to prevent it reoccurring. Common reason why dryer aborts after a couple of minutes.
    #325819
    adv
    ok dont no if dryer is aborting tho. need to ask customer. take it i have to split casing? to get to it? 😳
    #325820
    adv wrote:ok dont no if dryer is aborting tho. need to ask customer. take it i have to split casing? to get to it? 😳
    You don’t have to but splitting the case is the better way as you can also check and clear the fluff from the condenser at the same time. Also, just a thought, make sure to condenser valve is OK and water flows into the condenser? That too can be a source of no heat, worth checking. 😉
    #325821
    adv
    ok cheers
    #325822
    adv
    what are amp tags by the way?
    #325823
    Amp tags are 1/4″ Lucar connectors.
    Mike.
    #325824
    adv
    not herd of them either 😆 you meen crimp connectors? 😆
    #325825
    Yep.
    Mike.
    #325826
    pup
    adv wrote:what are amp tags by the way?
    well 🙁 🙁
    #325827
    adv
    spot on here lads thanks for priceless info 😆 😆
