Hi not had alot to do with AEG w/m’s but got one that doesn’t want to spin it washes ok but wont go into spin not even the distrbution spin.checked the two pressure switches & vipler hoses they seem fine tried it empty so it’s not a balance problem.What’s the likely culprit on these motor or module.Thanks Mack.
How old is it? Brushes are the most common fault on older ones. (IMLE)
=in my limited experience. Guess you must live in a hard water area as you’re checking pressure switches.
Mike.
PS, You’ll get fewer replies if you don’t give a model no.
