aeg waasher dryer
  • #14213
    mike1
    model L16810 prod 914601605 can anyone help with a problem on the above it washes ok and spins ok but wont dry theres no power to the element or the fan however the drum rotates as it should to dry! I think it could be a pcb fault does any one have expierience of this ?
    #158628
    Dave_Conway
    Re: aeg waasher dryer
    No error codes would indicate a faulty PCB.
    If you’re on broadband, I can send a hefty (5mb) config/test PDF if it will help ?
    #158629
    Go for the obvious Mike before fretting over the Module (last place to look actually 😉 )
    Valve open circuit? Overheat stat? NTC open circuit or earth fault on it? Trace the wiring back to source?…all good fun 🙂
    #158630
    mike1
    Thanks Dave I have sent you a P.M.
    Mike
    #158631
    Dave_Conway
    On the way 😀
    Sorry, I didn’t word the first line of my reply very well and didn’t finish it correctly.
    Martin has done it for me though :tup:
    #158632
    Flyman
    Fan does not come on until the element has heated to a certain temperature so ignore the fan and concentrate on the power to the element problem. Check diagnostics for an error code.
