AEG washer drier fault code????
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries AEG washer drier fault code????
  • #29304
    robwash
    Can anyone tell me what E10 means please?
    #222691
    Re: AEG washer drier fault code????
    C’mon Rob, what model?
    whizzkid
    E 10 is gonna be something to do with water fill problem.
    ie. water off, valve o/c, hydraulic circ etc
    #222693
    Providing that it’s really a Zanussi…….
    whizzkid
    would be an “f” code if it was an aeg?
    #222695
    robwash
    The model no is L16810 Lavamat Turbo cheers.
    #222696
    robwash
    Re: AEG washer drier fault code E10?????
    model no L16810 Lavamat Turbo . Flashing E10. can anyone help with this please.also has anyone got a list of codes for this model please? many tahnks Robwash
    #222697
    DentedPorsche
    Zanussi error codes for that one.
    E10 will be the code shown to the user, in diagnostics you’ll get the actual error code. It does signify a water problem though.
    If you’ve got the TDS disc then you’ve got the manual, if not someone may be able to help if you provide the product number.
    Brian
    #222698
    robwash
    HI. Finally seen the machine. The fault is with the drier. The wash cycles are ok.
    When you start the drier, you get drum action. but you get no drier fan, no heat, no fill on valve and no drain pump. after 10 mins of this it goes into fault code E10. I get 240v to earth at element but no neutral. checked all stats on drier heater and ok. Any help please Model no.L16810 Lavamat. cheers
    #222699
    whizzkid
    hi robwash,
    will most probably be inlet valve o/c
    triple valve on them, meter them out and i’m sure you’ll find 1 of em is dead!
    cheers neil.
    #222700
    robwash
    THanks a lot. it was the inlet valve. nice 1 mate
