I’ve been out to an AEG washer dryer flashing the E10 when drying. L16820 914602104.
Ive obviously had a look at the water valves and taken the hose of while working to check that is injecting water in. I’ve unblocked all the dryer condensor and its still flashing E10.
It will work the first time you dry, which it did for me, but its the second time the machine goes on that it fails.
I’ve heard that the solenoid could go open circuit during the dry cycle but why would it work for a full first dry and then not a second time.
I have ordered a triple valve for the machine just in case but was just wondering if anybody else has and wisdom they can share with me regarding E10.
By the way I completely forgot to go into diagnostics to get the engineer code. Will it tell me any different?
All help is greatly appreciated as usual.
Regards
Nick
