hi,
this machine looks very much like the zanussi washer dryer.
the machine works perfectly on wash but not on dryer,
the fan motor goes, the water goes into the condenser the thermostats and thermistor are ok the heaters are ok.
however there is no heat i suspect the pcb anyone else had this problem and can anybody give me a ballpark figure for the pcb.
If your getting power to elements during drying cycle that would say that the pcb is ok but your elements or stats are at fault. Are you getting a live and netural feed ?
Check the condenser valve coil and check the thermistor that is mounted in the condenser tank to tub hose. Wire to thermistor some times breaks.
Graham
