Aeg washer dryer L16830 sticks on 1 minute
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Aeg washer dryer L16830 sticks on 1 minute
  • #80828
    pete harcup
    Hi ,I have an aeg w/dryer that sticks on 1 minute at the end of the cycle ,if left will just keep going over and over again,pressure chamber and pipes checked and all ok ,any ideas from anyone ???? Pete.Ta.
    #414471
    Re: Aeg washer dryer L16830 sticks on 1 minute
    The symptoms are insufficient to offer a diagnosis. Various components will require testing (pump, motor, heaters etc). In the trade we also do the necessary insulation tests and interrogate the electronics for any error codes. Perhaps your best solution at this point is to seek help by calling out a local independent engineer.
    #414472
    pete harcup
    Hi Martin,
    I did interogate the software and got ‘E35’ ,which means water level too high,I have checked air chamber and tubing(all o.k.) large white pressure switch has 2 clicks when activated,black presses tat with thin blue wires mounted on control pcb doesn’t click but I’ve been told its not supposed to.could it possibly be an earth fault on element or motor ? …..Pete.
    #414473
    Andy jones
    Have you done an insulation test. That could tell you a lot
