This might be an intermittent fault because since cx booked the appointment it’s worked 4 times without failing….. I found the water filling not consistent, on some settings it fills like normal but on others it fills up slowly – stop it and try again then it fills normally?!!?
I waited for a wash to fill, it started normally then the flow sounds reduced until it stopped to start washing…. I’m assuming this isn’t correct as all the machines I’ve looked at fill up using the standard pressure, so why is this machine intermittently filling with a strong normal flow then changes to a weaker flow intake?!!?
Any ideas please?
Thanks Brett
