AEG Washer Dryer L75480WD E10 error code
Home Forums Public Support Forums Help And Support Washing Machine Help Forum AEG Washer Dryer L75480WD E10 error code
  • #91397
    Su5ie
    Hi there
    PNC: 914605605 00
    S/N: 304 00192
    My AEG washer/dryer tumble dryer (only) has stopped working and it is displaying the E10 error code. The washing machine is working fine. I bought it in 2013, it’s 4 years old. It used to intermittently stop tumble drying and display the E10 message, but would work properly for maybe the next 10 cycles. However now it won’t work at all.
    I have cleaned and drained the water from the drain pump filter, which wasn’t especially clogged up because I do it regularly. As advised by the AEG website I ran a wash with the drawer slightly open and can confirm there is water running on the wash cycle. None of this has helped.
    Other people have posted about this problem but with slightly different model numbers and have been told it could be the ‘Washing Machine Water Inlet Valve’. However the serial number’s do not correspond to my specific model, so I am not sure of the exact part.
    Any advice would be gratefully received. Sue
    #447931
    Re: AEG Washer Dryer L75480WD E10 error code
    It does require a new water valve to rectify. If you post the full PNc number of your machine (9??????????) shown on the serial number plate we can provide the correct part number for you.
    #447932
    Martin wrote:It does require a new water valve to rectify. If you post the full PNc number of your machine (9??????????) shown on the serial number plate we can provide the correct part number for you.
    she did Martin 914605605 00
    electrofix wrote:she did Martin 914605605 00
    I must get this cracked screen on my iPhone replaced 😳
    …anyway, here is the correct valve
    https://shop.ukwhitegoods.co.uk/1325188 … fill-valve
    :tup:
    #447934
    Su5ie
    Hi Martin and Dave
    That’s brilliant, thank you very much!
    Sue
