AEG washer dryer – L76685 nwd
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries AEG washer dryer – L76685 nwd
  • #101461
    asp11
    It stops on average 3 or 4 times mid cycle at the same stage each time (no error code appears, the machine just pauses). Also, occasionally the error code E10 comes up but the water supply to the machine is absolutely fine and it drains perfectly well.
    I’ve not been out to this appliance yet but just looking into some suggestions as it’s an intermittent fault?
    The error does appear to be a drainage issue, so why only fail sometimes!!
    PNC : 914605818
    #484829
    E10 codes are fill errors
    the electric valve may have a flow meter
    asp11
    That’s a place for me to start checking, thanks Dave
    #484831
    asp11
    electrofix wrote:E10 codes are fill errors
    I’ve checked the parts list on Connections…. it has a triple valve but no obvious flow meter, other than the pressure switch — so not sure how to proceed, could it be that the water coming in is too cold hence the fault being intermittant??
    #484832
    dont trust connect go to the source
    Showing parts and accessories for 91460581800 | Model L76685NWD | AEG UK
    its listing a valve with a flow meter and wiring diagram shows a flow meter as well
    Hollytree_Technical
    While I have not seen this specific model I can say that I have had multiple instances of electrolux water valve coils going open circuit after a couple of minutes of use (usually the dryer valve coil) but when left they come back again so you have to catch them in the act.
    Jem
