Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › AEG washer dryer – L77685 = No heat on dry
- This topic has 7 replies, 2 voices, and was last updated 3 years, 3 months ago by
asp11.
December 28, 2022 at 5:49 pm #101511
asp11
ParticipantThis doesn’t have any reset TOC….. It goes onto the heat setting but the fan motor doesn’t start and nor do the heaters but it pumps out during the heat cycle fine and is quiet when it should have the motor/heater in operation and there’s no clicking or sounds from the boards – Not drawing any amps inbetween the pump outs (just silent)
I’m confused as to why the pump works when it should during a dry cycle but not the dryer motor or heaters AND No error codes??
PCN : 914605802-00
SER : 30900013December 28, 2022 at 7:32 pm #485022electrofix
Moderatoruhave you gone into service mode and looked for error codes ?
have you checked water solenoid. Often these machines do a water check before starting dryer properly
December 29, 2022 at 4:14 pm #485023asp11
Participantelectrofix wrote: uhave you gone into service mode and looked for error codes ?
I don’t know how to put it into Service mode unfortunately and didn’t know about the vavle check – it washes all ok though?
Is there a test mode on here somewhere, it didn’t come up when I entered the model number?December 29, 2022 at 6:51 pm #485024electrofix
Moderatorhave sent you the service info
December 30, 2022 at 2:15 pm #485025asp11
Participantelectrofix wrote:have sent you the service info
THANKS Dave — I went back today and it did show up an error of = ed1
which is a communication failure between the boards….. the suggestion in the manual says to change the “WD satallite board” but I find that in the any part description, do they mean the dryer board or the main board… or are there more boards??December 30, 2022 at 3:54 pm #485026electrofix
Moderatori assume they mean the dryer board
might be part no 132 78 73-00 / 4
listed as £86 retail
have you check wiring and removed and replaced connectors ?
dont forget with a communication problem it can be either board or both
December 31, 2022 at 11:30 am #485027asp11
ParticipantYes I’ve checked the wiring going to the dryer board and my research shows the same part number, so I’ll quote the customer and see what happens….. THANKS again Dave for your incredible knowledge Happy New Year!
January 9, 2023 at 5:55 pm #485028asp11
ParticipantJust to confirm and help any future engineers — The dryer Pcb did solve the problem……. Ta Dave!
