I’ve checked the few past posts on this model but they weren’t relevant….
The washing machine side works fine…….. The dryer part starts normally until the motor/heater kick in
The board clicks and there’s power to the heater for a few seconds only (checked with my amp tester) then it does the same again…… then stops, the door lock clicks and it can’t be restarted – there’s no fault code and the display stays the same as the selected setting?
Both dryer heaters are around 66 ohms, the NTC at the front works and the wiring to all dryer parts is good
Any ideas please?
