AEG washer dryer – Timer resetting to zero on dryer programs
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries AEG washer dryer – Timer resetting to zero on dryer programs
  • #58482
    A1_Domestics
    model number is: L16830
    Pnc: 91460212200
    My megger is in the process of being replaced, so assuming it was the element I replaced that last week. It worked on one Iron dry program before it started with the initial symptoms again.
    I have the service manual from TDS but it does not mention anything useful.
    Any clues guys?
    #334685
    martinm
    Re: AEG washer dryer – Timer resetting to zero on dryer prog
    common for the condenser to block near the top as its very narrow there, in turn affects count down time or aborts
    #334686
    A1_Domestics
    I should mentioned that I cleared the gunk from the condenser and checked the wires on the stat.
    #334687
    Wonder if it’s one of those with the dodgy green solenoid coil?
    Mike.
    #334688
    A1_Domestics
    I replaced that last year. Can see it working away at the mo. But it could be intermittent so I’m popping by this afternoon and watch it go.
